Re: irrigation system
Posted by BlasterStumps on March 31, 2017 at 18:11:51 [URL] [DELETE] :
In Reply to: irrigation system posted by AL CT on March 31, 2017 at 14:10:35:
I presume you are putting in a sprinkler system? If I was putting a new system in, I would make each zone drain to a low-point drain. That may require trenching so that you can control the fall on the line(s) and not have low spots in the run. I don't like having to get an air compressor to blow out the system.
Mike in CO
