In Reply to: Attention All Early 9N Owners -Survey posted by Tim Daley(MI) on February 13, 2013 at 20:50:28:
OK, so many fellas have a 'B' or a 'C' generator. Both are 1-wire, three brush units. The 'B' has the HI-LO slider button for third brush adjustment and the 'C' changed that to an adjustment screw. The 2N10000 generator was virtually the same as the '9N-10000-C' generator with the addition of two screw holes drilled and tapped to accept the tensioner bracket.
Question #1-
Do you have a 'B' or 'C' generator on your early '39 9N because you don't have the correct 'A' generator or the correct 9N-10505 Voltage Regulator or both?
Question #2-
If you are happy with your 'B' or 'C' setup and have an early 'A' generator and/or voltage regulator on your bench, would you consider selling one or both?
Question #3-
If you have an original 9N-10000-A generator but do not have the voltage regulator and wish to keep it to use on your early 9N, how interested would you be to buy a reproduction 'A' voltage Regulator with solid state guts?
Quesion #4-
If you have the original voltage regulator but it is fried, how interested are you in getting solid state guts put in it to make it functional?
Polling results to be posted soon...
Posting not permitted in the forum archives.<1360857660">
