In Reply to: Tight Engine,,,Rebuild posted by Charles (N.C.) on August 12, 2010 at 09:07:29:
Charles,
Be sure to use assembly lube.
I also oil the rings, pistons, and cylinders with 20 weight oil, and put a little in each cylinder once assembled. Turning it over might be tight, but should be smooth.
Be sure to prime the oil galley. (see how to's section). If the starter will turn it, it should be OK. I usually crank the motor enough without spark plugs to see if the oil pressure will come up on the gauge. HTH...S.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_12028851-P_x_x?cm_mmc=CSE-_-Google-_-VALUE3-_-VALUE4&ci_src=14110944&ci_sku=12028851
Posting not permitted in the forum archives.<1281630715">
