In Reply to: Lift arms & Adjustment arms ??? posted by Charles (N.C.) on September 28, 2009 at 16:12:32:
I'd ask you if it's an N.........but the hall monitor might get testy w/ me! :)
If it's an N......the standard 3-point lift arm "balls" should lower to about 8-1/2" above ground and raise to about 34-1/4". Total lift range is 25-3/4".
Try the quadrant adjustment.
If that doesn't work, I'd just leave it be because the next adjustment is under the top cover. That tends to mess up the paint job as well!
Posting not permitted in the forum archives.<1254169537">
