In Reply to: Sealed beam bulb loose posted by Mark on November 13, 2016 at 07:05:19:
Thanks for the info. Mine are Tract-o-lights and the tractor is a 1951. The sealed beams that came out both had a tight fit. The new sealed beams are USA made and were bought at Just 8Ns, so I believe they are correct. It is likely just a small difference in size tolerance of the bulbs. I will try the tape or rubber wrap under the "door".
Posting not permitted in the forum archives.<1479145464">
