In Reply to: Need help with rare 9N value posted by Chic on April 10, 2016 at 21:07:27:
Value on these often is underrated depending on how original they are. The grille should be aluminum with horizontal bars, and NOT chrome. Original puts value up there, if a repop, not so much. Ditto for the 4-spoke steering wheel. Since it is a 12v confusion, that means the original small 'A' generator with the square voltage regulator are gone too, right, and that brings the value down as well. How about: The key switch on the dash? Starter button on dash? Ignition 'ON' lamp in place -doesn't have to be hooked up, but if still there that's a plus; original gauges? Should have the 20/20 ammeter; the original non-pressurized radiator with chrome Stant cap? Snap-in/non-hinged battery access door? Double ribbed fenders? Adjustable left lift arm? CM HALL headlights? TAURUS taillight? Smooth rear axle wheel hubs? 4 x 19 single rib front tires? Cast iron governor with NO oil line? Toolbox? So, there are quite a few more things one has to know before putting a price on it...The low s/n does not necessarily mean it is the original with that tractor either...especially if block has been welded...add pictures, as many as you can with detail on close-ups in particular.
Posting not permitted in the forum archives.<1460376992">
