In Reply to: Re: naa govenor oil leak posted by Ron and Mary on October 23, 2014 at 14:28:12:
Hi Ron and Mary, Since I've already got all the sheet metal off (to restore it) and I have a leaking radiator and I also have the front end loader of to test fit the new FEL, before painting. I figured now would be a good time to do the governor oil leak. In order to do the governor oil leak after all the aforementioned is removed the front axle and bolster (support) has to be removed then the belts and pulley from end of crankshaft has to come off. It has been 13 years since I remaned the engine so I don't remember if water pump has to come off also, although I don't think it does. If memory serves me correctly only the cover for the governor has to come off to replace the seal. Of course the linkage to carb., also has to be disconnected. I was hoping there was something in manuals section on naa governor to help jog my memory before I got fully in to it but I think I remember most of it, I also have the paper manual around here some where. Thanks and God Bless, B&A.
Posting not permitted in the forum archives.<1414097133">
