In Reply to: Re: governor, what am I seeing? posted by JMOR on July 18, 2014 at 12:50:11:
Yep, it's shaped like an acorn nut with a hole through it. The threaded "hook" goes through the hole in the top of the acorn. There is a small spring between the nut and the flat piece of metal. I assume it's to put retension on the nut, so it doesn't vibrate off.
Posting not permitted in the forum archives.<1405705505">
