My brain ain't working right today, am I doing this right?
Posted by Farmer Dan on June 28, 2014 at 15:55:04 [URL] [DELETE] :
Not sure if it's the heat or the humidity or if I'm just having a bad day but I can't seem to get my mind to concentrate on which way all this stuff rotates.
I should have the tab for the timing jig on right. At this point I adjust the plate so the points are just starting to open. Right?
Then to get rid of my spark knock I need to retard it, I'm shooting for 2 degrees. That would require moving this little plate UP right? The hash marks are 4 degrees so if I go up 1/2 I should be 2 degrees retarded or late correct?
Posting not permitted in the forum archives.<1403985304">
