Re: govenor noise???
Posted by mhb@ufe on June 04, 2014 at 07:40:21 [URL] [DELETE] :
In Reply to: govenor noise??? posted by greg durdik on June 03, 2014 at 21:37:57:
The governors can wear to the point that the balls inside travel out to far and make contact with the inside of the governor housing and make quite a rattling noise. Pretty easy to pull the governor off and check. There is a good tutorial in the How to section of this site to help you with the rebuild if needed.
Mark
Posting not permitted in the forum archives.<1401882020">
