Re: 9N governor??
Posted by Farmer Dan on May 28, 2014 at 21:37:02 [URL] [DELETE] :
In Reply to: 9N governor?? posted by Les Leach on May 28, 2014 at 21:21:02:
On a properly running and warm engine if you apply choke it should stall. That tells me you have a carburation problem. I would clean the carb making sure to get all the passages and jets clean, then check timing.
Posting not permitted in the forum archives.<1401327422">
