Re: another plow ?
Posted by lonestarjeff on May 28, 2014 at 18:36:04 [URL] [DELETE] :
In Reply to: Re: another plow ? posted by jim in pgh on May 28, 2014 at 14:33:36:
If the hydraulics are working right added weight won't be necessary. Makes me think something is out of adjustment internally, or a sticky valve.
You should be able to adjust the depth of cut by how low you set the quadrant lever. My 8N has always been easy to set up & adjust, but my 860 is a bit of a pain to use in draft mode, like yours.
Posting not permitted in the forum archives.<1401316564">
