Re: Select-o-speed
Posted by ZANE on May 19, 2014 at 19:00:15 [URL] [DELETE] :
In Reply to: Select-o-speed posted by poderac on May 15, 2014 at 14:22:49:
The following is a procedure that I myself came up with years ago while trying to hold the screw in the self locking nut from turning and not having much luck. (necessity is the mother of invention!)
Be sure to disengage the coupling between the transmission and the differential to prevent possible injury.
The engine must be running at idle.
The bands are easy to adjust but the hydraulics of the trans. must be working in order to do it. If you will put the transmission in the gear a particular band is supposed to be engaged you will be able to release the lock nut without the adjusting screw moving. If on the other hand the adjusting screw moves with no resistance when you have it in the gear that is supposed to have that band applied you can assume you have hydraulic problems with what ever is supposed to be applying the band.
After you have turned the lock nuts back on each band then you can turn the adjusting screw in till you feel the engine begin to load because you will be doing the same as trying to put the transmission in more than one gear by removing the clearance in the band that is supposed to be disengaged at the time. Then you need to turn the adjusting screw out 3/4 turn. Put it back in the gear that puts tension on the adjusting screw and tighten the locking nut. The reason you do it this way is because it is almost impossible to hold the screw while tightening the lock nut when the band is disengaged. Do this procedure on all three bands except that the front #1 band should be backed off only 1/2 turn because it is the smallest diameter of the 3 bands.
Posting not permitted in the forum archives.<1400544015">
