In Reply to: 9N Distributor posted by Farmer Brown on May 17, 2014 at 15:51:38:
I understand that you adjust the timing of the distributor with the distributor off of the tractor. However, is there a way to see if the timing is correct with a timing light as you can do with cars so that you can see you have it correct?
Posting not permitted in the forum archives.<1400420077">
