Re: NAA Governor / Carburator
Posted by Walt/Tx on May 02, 2014 at 16:11:15 [URL] [DELETE] :
In Reply to: NAA Governor / Carburator posted by George (NL) on May 02, 2014 at 15:11:24:
You may just need to adjust the gov/carb linkage. My Jub is set to cycle back at 2100RPM (aftermarket proofmeter reading, not sure just how accurate it is). In this pic, the pen points at the rod carrier which serves as a stop for the adjustable stop on the rod. My stop is 2.5" from the nut at end of gov spring, inside measurement. The gov spring is to the left, out of picture. Hope this helps a bit.
Posting not permitted in the forum archives.<1399065075">
