So in the process of putting this project back together I had a problem with the carb which is on its way to being fixed. Now my next (hopfully minor) problem is an antifreeze leak that I cant, for the life of me, figure out. Maybe someone has had this happen to them? I have the hose connected from the pump to the radiator and it's tied down at each end with a hose clamp. However it leaks from the top no matter how tight I make the clamp and no matter how I adjust the hose. I've even drained the radiator, took the hose off flipped it around and still no good. Any ideas what I may be doing wrong?
Posting not permitted in the forum archives.<1394564114">
