Mostly disassembled and mostly cleaned up. Hood, instrument panel, oil canister, radiator, manifold, distributor, governor, all front steering and support, etc. all removed. Down to the fan belt pulley and steering box. The oil canister bolt that sheared off has been re-tapped. New spindle bushings have been installed. Rear hub wobble issue has been solved. New gaskets in valve covers, governor.
Next on to getting the miscellaneous dings out of the hood and fenders, put the front end back on, clean up the box rims and get some new tires. Lots of new bits to buy from Dennis Carpenter. Get the radiator cleaned out and tested.
It's starting to look do-able! Thanks for all of your help so far!
Do you typically re-finish the rims before putting new tires on? Or after?
Posting not permitted in the forum archives.<1391616337">
