Re: Shop Temperature
Posted by Rockbiter on January 27, 2014 at 18:02:56 [URL] [DELETE] :
In Reply to: Re: Shop Temperature posted by TheOldHokie on January 27, 2014 at 15:45:12:
Some of you fellas have some nice shops. You would probably laugh at my setup. My "shop" is actually in our garage which means I share space with the car. If I want to do any mechanic work, I have to move the car out.
Our house has hydronic heating and the boiler for that is out in one corner of the garage. The only heat out in the garage so far comes from the few feet of exposed piping from the output side of the boiler/sidearm to where it enters the wall of the house. At best when it is cold cold, that little bit of piping can keep the freezable liquid stuff in the garage from freezing. I probably should get a small register put in out there in the garage. As it is, I don't spend much time out there when it's cold out.
Posting not permitted in the forum archives.<1390863776">
