In Reply to: 9N Clutch replacement posted by JEFF STCLAIR on November 26, 2013 at 22:55:52:
There is a big difference between adjusting a clutch & replacing one.
To replace the clutch, you need to split the tractor.
To adjust it, you remove a pin & a bolt & turn a clevis.
Which do you need done: replacement or adjustment?
Posting not permitted in the forum archives.<1385592830">
