It appears that the clearance between the fork base and the washer on the governor drive shaft is critical since it is named Go-No Go. Does anyone know of a commonly available item that is between .22" &.23" thick that can be used to insert in this gap to measure & set this clearance? My caliper is not that precise and can't be inserted.
Posting not permitted in the forum archives.<1382292400">
