Re: 3 point lift question
Posted by kevin on October 14, 2013 at 12:18:09 [URL] [DELETE] :
In Reply to: Re: 3 point lift question posted by ZANE on October 09, 2013 at 21:32:00:
Zane, I actually was a GM tech the whole time but everything still runs with the same principal. Does it not have spark or no fuel. Generally all you need to do to adjust the TPS is have an ohm meter attached and adjust the sensor to read .40-.60 ohms. As far as what I read on the other posts about reseting the computer, on GM cars all you ever needed to do was clear the codes and good to go.
Posting not permitted in the forum archives.<1381767489">
