In Reply to: Re: stumped>>>> posted by JMOR on September 15, 2013 at 19:19:04:
yes, that is how its configured. thank-you, I was absent minded not to think ccw. as I said before, with just a screw driver I can tell the difference in the spark. she doesn't use oil, doesn't smoke. 50lbs of constant oil pressure, you cant adjust the timing, can you ? I will buy new plugs next, check for grounds and such, but with the spark difference, and how at times it wants to run, i'm leaning towards some corrosion in connection or something like that. Maybe the distributor I purchased is already faulty. Mechanically speaking I think my flattey is fine. Just I was born in the age of H.E.I, points have always baffled me. and I owned a dual point distributor on a 72 nova, well just for just a little while that is. Mallory to the rescue.
Posting not permitted in the forum archives.<1379292791">
