Hyd lift travel update
Posted by Drake on July 22, 2013 at 19:05:06 [URL] [DELETE] :
49 8N ... I had a problem with the 3 point only lowering to 19 inches, adjusted the quadrant some and was able to get it to lower to 15 inches. Talking with Mr. Sherman today, he had suggested I look at one of the a connections on my lift. Something was not right as it should drop all the way down when the draft control lever was in the forward position. It all seemed to be to be connected right. I adjusted the leveling box all the way out, I thought. Disconnecting the bottom of the level box, the lift drop all the way down. After checking the LB, somehow the threaded shaft was bent inside preventing it to lower. Duh me! I straightened the shaft and all seems well. Now all I need to do is adjust the lift cover. Awaiting his jig to do.
Thanks again Mr.S.
Posting not permitted in the forum archives.<1374534306">
