I just bought a 9n last fall . This spring we started doing some discing ect and it stopped running. It had an original manifold on it that had been welded a couple of times so I replaced it .After I replaced the manifold I noticed the ignition coil was cracked and replaced it . It still would not start. I tested the resitor and found it bad and replaced it and I did get it running.I went ahead and did a complete tune up on it plugs ,wires,cap, rotor, button, points ,condenser ect.I pulled the distributor and double checked the point gap and it was good I did not try and adjust the timing . The tractor is still not running right it seems to be missing and stalls sometimes ect, lacks power. I am open for suggestions or if someone knows someone in the Northern Kentucky area that can work on it I would apprciate it.
Posting not permitted in the forum archives.<1370095816">
