Saw a post recently where someone was having a problem with their "N" not idling down, don't know if they got the problem resolved but I was having the same problem.
Throttle was in the lowest notch on the quadrant but would not idle down. I cleaned and replaced some parts in the carbuerator and did the same with the govenor, also tried to adjust the settings on the carb and govenor. No luck, still fast idle. I did find that if I grabbed the linkage from the govenor to the carb and gave it a pull towards the govenor it would come to an idle. I ordered a new rod assembly
(9N 9818-A) thinking my old one must be worn was the problem. The new rod came and I insalled it and still the same hi speed idle. I removed the new one , put a bend in the old one, re-installed and that solved the problem. Now it idles, accellerates and runs as it should. Sometimes its the simplest thing!!
Posting not permitted in the forum archives.<1363650378">
