In Reply to: Need a Ford 2000 Mechanic Near Charlottesville posted by Rick Gowdy on April 08, 2024 at 08:36:48:
You should always mention if the 2000 is a 1962-64 four cylinder model or a 1965- 75 three cylinder model.
That said, maybe try it your self?
If you can keeep an N running you can keep a 2000 running. They are not so different after all. Like, points are points and carbs are carbs and testing for spark or fuel is pretty much the same for any tractor except maybe if it is a diesel.
I had a couple of Ns and managed to keep them going. Then I bought a 3 cylinder 2000 and found that though it was different, it wasnt THAT different from an N. In fact is seemed rather familiar after all.
