Re: Tractor jack
Posted by Steve Dabrowski on March 29, 2024 at 15:05:13 [URL] [DELETE] :
In Reply to: Re: Tractor jack posted by Tim Daley (MI) on March 27, 2024 at 15:31:09:
Hi Tim,
Not sure why voicemails do not respond-I switched to Xfinity mobile from Verizon, but they run on Verizon's system and I get VM's on the mailbox I had with Verizon, Xfinity wanted me to set up a VM, but since calls seem to work with the old setup I have never bothered. Most of my calls come from within CA so maybe out of state doesn't work. Xfinity is kind of flaky but lots cheaper than Verizon. Phone number is still the 510 one and email is still the same. I'll send one to your's next week.
The plans for the jack are really clear, but steel tubing usually comes in differing wall thickness I think, I doubt they used schedule based pipe. The plans don't show that, although the ends used for attachment to lifting arms should be open and the wall thickness of those easily measured, and that should be a pretty good clue to the thickness used elsewhere on the various members. Just thought about that this morning.
Good to see you on the Board. I'll try to get back to you next week.
