In Reply to: Re: Jubilee remote hydraulics posted by Harlan Horton on March 18, 2024 at 22:07:07:
Not the first time this question has been asked. I suspect that is a double acting valve set up for use on a single acting cylinder. The tube simply dumps pressure from the unused port to tank so as to not deadhead the pump.
Easy to test - remove the tube and hook up a hose to verify two way flow.
Dan
