Re: ATTN: TOH - TIMNG JIG
Posted by Ed Gooding (VA) on March 02, 2024 at 13:24:33 [URL] [DELETE] :
In Reply to: ATTN: TOH - TIMNG JIG posted by Tim Daley (MI) on March 02, 2024 at 11:46:20:
This guy has already sold 18 of them and it looks like he manufactured 25. Here is his description of the item and he references Dan:
Holds distributor shaft in precisely the FORD specified position for setting Front Mount distributor point timing on FORD 8N & 9N tractors. This is CNC Machined Precision improved version of “The Olde Hokie's” original tool that is now unavailable. While the concept is the same, the dimensions and execution/spacer method has been improved - along with the accuracy. You can time your old FORD, or aftermarket, front mount 8N & 9N distributor with confidence using this tool and the enclosed instructions. Super easy to set up. The distributor IS NOT INCLUDED. 100% made in USA......Aftermarket FORD procedure compatible.Shaft Locking and Alignment tool for timing either FORD or aftermarket FRONT mount 9N & 8N tractor distributors
[ Follow Ups ] [ Post Followup ] [ N Board Forum ]
