In Reply to: Re: MS Carb Needle Wire Bale ? posted by Tim Daley (MI) on February 19, 2024 at 06:29:59:
I had set my floats using the 1/4" spec and had repeated flooding problems and then I picked up on the 9/32" spec and adjusted the level and so far have had no further flooding and easy starts. I also have taken both the carbs apart and surfaced the bowl gasket face on the cross table of my mill using sticky back 180 grit sand paper before setting the float levels which ensures a good seal of the float bowl area from the intake stream.
