In Reply to: Re: NAA piston pump O-rings choice posted by TheOldHokie on January 27, 2024 at 16:14:27:
Thank you TOH. Got the O-rings coming. I've tried nearly everything under the sun to get the dang thing to quit leaking but nothing has worked so I sure hope these seals from Messicks will do the trick.
You all are great folks and I sure appreciate the help.
Mike in CO
