In Reply to: FLICK posted by DANIEL on January 25, 2024 at 13:44:04:
You meant a 1950 8N. It should have the front mount distributor and the OEM Ballast Resistor, right? 6V or 12V, just be sure wiring is correct for whichever system. The N's aren't geared for Rototiller Use. You say you have a plow and a disc. Those are sufficient to work food plots and gardens. You could find an old Dearborn Spring Tooth Harrow and 2-Row Cultivator to add further. SEE MANUALS forum for more info & LINK. There was Howard Rotavator made but NLS and parts non-existent.
1948 FORD 8N & DEARBORN 13-2 CULTIVATOR:
Tim Daley (MI)
