Re: Crank shaft pulley
Posted by TheOldHokie on March 20, 2021 at 07:01:50 [URL] [DELETE] :
In Reply to: Crank shaft pulley posted by Rich on March 20, 2021 at 06:37:00:
The OEM pulley was a stamped steel sheave riveted to a solid steel hub.
The aftermarket pulleys are solid steel. They are much stronger and the holes allow them to be used to drive a front mounted hydraulic pump.
My preference is the 192160 pulley - modestly priced and easily adapted to front shaft drive pumps. A significant improvement over OEM. The 192152 pulley with rubber grommets is an expensive and poorly conceived PITA.
Don't be concerned - be happy you have an easy and inexpensive fix for your worn pulley.
TOH
