Re: dearborn dozer blade for jubilee
Posted by Ultradog MN on March 09, 2021 at 07:31:21 [URL] [DELETE] :
In Reply to: dearborn dozer blade for jubilee posted by ward hill on March 06, 2021 at 19:39:37:
If you are looking to use it to plow snow you will be much happier with the snow blade rather than the dozer blade. Snow blade is a bit taller and has tip springs on it.
Ford made several front push frames over the years. For Ns, NAAs, Hundreds and even the 3 cylinder Thousands. Some were cable lift, some hydraulic lift. However, the blades were identical all through the line up. So a blade for a 1950 8N push frame will fit a 1970 3000 push frame.
Means you can mix and match if need be. Find a frame here and a blade there, etc.
Properly set up with rear ballast and tire chains these Fords make awesome little snow movers.
