In Reply to: Re: Carb (I think) posted by Rick Douglaz on February 26, 2021 at 20:35:41:
Have you checked for a vacuum leak? Spray your starter fluid around the manifold including the joint where the carb attaches while trying to start it. A helper helps!
Had similar problem on my 2N. Carb attachment gasket had dried out/worn out and revealed someone had drilled an extra hole through the carb flange. A little epoxy and new gasket, problem solved.
