In Reply to: Arps Half Tracks Performance posted by Jeff in Northern Michigan on February 12, 2021 at 20:40:47:
Can we assume you are using a front blade or Vee-Plow? We can't see the fronts in this photo but in the OEM ARPS manual it is shown using a 2000 which would have 16" fronts. Would front wheel weights help? I had 6.5 x 16 fronts on my 8N and added the Ford 2-pc front wheel weights for my wintertime snow plowing setup, but only used a rear blade, no Halftracks, and they worked great. My 11.2 x 28 rears were loaded with Beet Juice (Rim Guard) and I did not use any chains. I did NOT have the luxury of a SteelCraft Cab though!
Is This You Jeff???
