Re: Grease proof meter?
Posted by G.W. in Tenn. on February 13, 2021 at 13:42:50 [URL] [DELETE] :
In Reply to: Grease proof meter? posted by pointer80 on February 12, 2021 at 19:11:28:
The operators manual states when it becomes necessary to replace cable, replacement cable must be lubricated. Spread a thin layer of graphite grease over lower two thirds of cable. When cable is reinstalled, lubricant will spread over its entire length. Over lubrication may result in failure of proofmeter. I personally have had good results using ordinary chassis grease.
