Re: How to get a stuck breaker plate out of distributor?
Posted by Tim Daley(MI) on February 06, 2021 at 07:43:15 [URL] [DELETE] :
In Reply to: How to get a stuck breaker plate out of distributor? posted by Matt on February 05, 2021 at 17:48:34:
Assuming you are talking about a front mount distributor? It's a tight fit but it'll come off once the large spring clip is removed. Try gentle, even tapping from behind on the cam/weights. Housing is aluminum and plate is steel so can't be rusted on -UNLESS you have one of the optional cast iron distributors offered since 1943.
