Re: shifter stuck,,, again
Posted by Gaspump on February 03, 2021 at 16:05:59 [URL] [DELETE] :
In Reply to: shifter stuck,,, again posted by Chy NY on February 01, 2021 at 16:44:05:
If you have a recurring problem of sticking in two gears a worn shift gate is the likely cause. The shift gate is part of the shifter on the transmission cover assy. I repair them with the cover removed but not removing them from the cover by building up the worn fingers with a mig or tig welder. I then grind them with an angle grinder to the correct shape. It is easy to see the wear on the fingers as all fingers and should be uniform. Go by the ones with no wear and rebuild them all accordingly. Not a difficult job as welding repairs go and when done you will notice a huge difference in the way it shifts and no more sticking in two gears. Or, you could locate and buy a replacement cover but check the gates before you buy it.
