In Reply to: Re: Response to Tim Daly posted by Beth And Allen on January 24, 2021 at 10:29:46:
Hi Kimberly I've got "ALL" the gas leaks stopped for now. Even though the assembly is most likely a Ferguson part, as Tim Daley stated, it is identical to fords assembly. Most likely have been put on in the very early life of my tractor since I've had it for over 20 years. My Question is, where did you find an O-ring to fit the valve stem? I would much rather just put in a new O-ring when (and if) it ever starts to leak there again, than buy a maybe it will fit part. I already have an over abundance of will fit parts that don't. Hope you can tell me the size and or where to buy those O-rings. Thanks and God Bless, Beth and Allen.
