Re: Turns over won’t start
Posted by Kevin on January 21, 2021 at 00:15:46 [URL] [DELETE] :
In Reply to: Turns over won’t start posted by Nicholas Coakley on January 19, 2021 at 08:39:50:
Very simple machine. maybe 6 wires total. I just bought a 9n with a rats nest of wires in it to make a 12v conversion work. Had the same problem after replacing everything that was bad, damaged, or severely worn. Turns out it was a the cable from the battery to the start switch. Had a bad spot in it but inside the shielding. Replaced that and it starts fine now. Check for worn/ bad wires
