Bought a 9N for use and perhaps restoration.
Problem is it had a badly done 12 v conversion. Mostly a rats nest of wires here and there to make it workish. I rewired and every thing works now except the belt. The alternator keeps throwing the belt now. Is there a good alternator mounting conversion kit out there? This one was a home job that worked on, the whatever alternator they had laying around, but does not work with the one wire alternator I bought to replace it and also puts the it out over top and dangerously close to the steering knuckle( a good dip and I bet I need another alternator) . Im stumped because the alignment looks straight. Lines up straight with a straight edge but still throws the belt even at idle. Any help would be great. Thanks in advance
Kevin
