In Reply to: Re: Turns over won’t start posted by Nicholas Coakley on January 19, 2021 at 13:19:52:
That might have something to do with it.
And it is leaking because the key got left on.
Your points are probably toast as well.
Pull the distributor, check bushing wear and insure that the advance works. Replace the points, set the gap and then set the timing .
See tips 66, 67 & 68.
