Lube Plate (part 4150)
Posted by Kimberly on January 18, 2021 at 18:47:39 [URL] [DELETE] :
I am going to put my tractor back together and use it. Maybe if I ever managed to get the parts from my friend I will go back into her. The incident cracked off part of the front pinon gear bearing race. It cracked where the pin went in to secure the lube plate. The issue is that the lube plate can swing over where it could possibly get into the ring gear on the differential. I have repaired the differential where I can use it. I am unsure to how to secure the plate at the top now. Also, the plate got bent; anyone have a photo of how it is suppose to be shaped?
