In Reply to: Re: Ignition Switch posted by Tim Daley(MI) on January 14, 2021 at 12:15:07:
The bad switch was NOS in Ford packaging with vinyl covered wires.
The ignition cuts out sometimes while running because the switch loses continuity.
A "key-on" warning light shows the problem.
It takes several swipes of the contacts to get continuity before starting.
I haven't used the tractor enough since refurbishing for it to be a priority, but switch replacement is definitely needed.
