Re: Original look
Posted by BW on January 14, 2021 at 21:03:49 [URL] [DELETE] :
In Reply to: Re: Original look posted by Steve Dabrowski on January 14, 2021 at 20:27:55:
Steve...thanks, you have obviously put in a ton of work to keep it as original as possible (and the pictures I have seen of your tractors are quite impressive).
Originally set out with a goal of restoring mine in the same way but I dont expect quite the same results for my first project. Every piece of the tractor will have been rebuilt and my goal is to get it painted correctly for now. Figure I can always work on (swap out) some of the smaller details like the ones you mentioned once it is up and running (all major parts are original).
Or...if it turns out as I hope, may have to pick up another one...learning a ton from this one (and this forum)
