Re: Original look
Posted by Bruce(VA) on January 12, 2021 at 16:59:02 [URL] [DELETE] :
In Reply to: Original look posted by BW on January 12, 2021 at 16:36:17:
PART NAME
8N COLORS
PART NAME
8N COLORS
Air cleaner
Red with decal
Guage Faces
Black-White Letters
Axle Housing
Red
Guage Trim
Black
Axle hub
Red
Hood
Lt Gray
Battery cable
Black Insulation
Hood Side skirts
Lt Gray
Battery cover
Red with decal
Ignition Switch
Unpainted
Battery tray
Red
Light Switch
Unpainted
Battery/Fuel Door
Lt Gray
Lug bolts & nuts
Zinc plated
Battery/Fuel Door Knob
Black
Manifold
Red or Flat Black
Brake drums
Red
Muffler and Pipe
Black or plated
Brake pedals
Red
Oil Filter
Red with decals
Breather cap
Red
Oil Filter Bolt
Zinc Plated
Cable Ends and Hardware
Unpainted
Oil Pan
Red
Carburetor
Red or unfinished
Position Control Lever
Red
Choke knob
Unpainted Metal
Proofmeter Face
Black-White Letters
Clutch pedal
Red
Proofmeter Trim
Black
Cylinder Head
Red
PTO Knob
Red or Plain
Dash Panel
Red
PTO Lever
Red
Distributor Cap
Black Plastic
PTO Shaft Cover
Red
Drag Link
Red Black Boots
Radiator
Black
Drawbar
Red
Radiator Cap
Black
Engine Block
Red
Radiator Hose
Black Rubber
Fan
Red
Radius rods
Red
Fan belt
Black Rubber
Rear End Housing
Red with PTO decal
Fan shroud
Red
Rear rims
Zinc plated
Fender mounting bolts
Unpainted
Rear wheel centers
Lt Gray
Fenders
Lt Gray
Running Boards
Red
Ferguson emblem
N/A
Seat & Spring
Black
Ford emblem
Silver script and edge on Red
Spark Plug Wire Tube
Cadmium-Plated
Front Axle Extension
Red
Spark Plug Wires
Unpainted-Black
Front Hub
Red
Spart plugs
Unpainted
Front Rims
Lt Gray
Starter
Red
Front Timing Cover
Natural Aluminum
Starter Button
Unpainted-Steel
Fuel Line
Unpainted-Steel
Steering Wheel Nut
Plated Acorn Nut
Fuel tank
Cadmium-plated
Three-Point Hitch Arms
Red
Gearshift
Red
Throttle lever
Cadmium-plated
Gearshift boot
Black
Throttle lever base
Cadmium-plated
Gearshift knob
Red (early) Black plastic (later)
Tie rods
Red
Generator
Red
Timing Cover bolts
Zinc Plated
Grill
Lt Gray
Toolbox
Red
Hood
Lt Gray
Touch Control Lever
Red
Transmission Housing
Red with PC decal
Valve Covers
Red
Ground strap
Unpainted
Wire Harness
Unpainted
