Re: What is this light
Posted by Tim Daley(MI) on January 12, 2021 at 06:11:50 [URL] [DELETE] :
In Reply to: What is this light posted by Scott Jongbloed on January 11, 2021 at 23:07:57:
I can’t open your LINK so can’t see any photos, but the first early 9N’s, til s/n 25000 used an Ignition ‘ON’ Lamp located just below the AMMETER on the lower LH dash panel. The Ignition Key Switch was also located on the RH dash panel. There are many other early 9N parts that may or may not still be original on your tractor –snap-in battery cover; aluminum horizontal bar grille, 4-spoke steering wheel; double ribbed fenders, small ‘B’ GEN and more. Your 9N may have been switched over to 12V so if your battery is 12V and you have an alternator, it would have fried the 6V bulb a long time ago. Go to the LINK below to learn more about the N’s and also in our MANUALS forum you can find all the 9N Master Parts Catalogs and download copies for yourself –they’re free. The very first early 9N MPC is the March 15, 1940 version. If your dash lamp has been painted over, it’s possible that it has been rewired and no longer works or the lamp itself is burned out. The OEM ignition lamp is NLA (No Longer Serviced) meaning parts are no longer available, except you can get the bulb so if all the rest of the socket is intact, may just have a burnt bulb. The MPC’s only list the dash lamp assembly as p/n 9N-3702, with no other individual parts except the lens, p/n 9N-3701, the wire, 9N-13603, and the Bulb, p/n B-13466. This is the same bulb that is used in the TAURUS taillight, industry standard #63. Like I said if your system is now 12V and you want to try the lamp, get a #67 (12V) bulb. Start here for more info and if you want more help, my email is open.
1939-1940 FORD-FERGUSON 9N DASH:
*NOTE: EARLY 9N DASH w/IGNITION ‘ON’ LAMP; LIGHT SWITCH (OPT’L), AMMETER, & PUSHBUTTON START SWITCH ON LH; IGNITION KEY SWITCH, OIL GAUGE, CHOKE KNOB ON RH PANEL.
9N IGNITION DASH LAMP PARTS:
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
