In Reply to: Re: electron ignition posted by Bfordn24 on January 11, 2021 at 17:16:14:
You have a problem that EI might not cure. Best find out why you are only getting 6 months out of a set of points.
You won't be happy to spend $130 for EI and have the same problem.
I own 4 8N's, all 6v and all w/ points . They start and run fine regardless of the weather.....and always get at least 5 years from a set of points.
See tips 66, 67 & 68 before you drop a lot of $$$ on something that does not fix your problem.
