Re: Mairose
Posted by TheOldHokie on January 07, 2021 at 01:45:48 [URL] [DELETE] :
In Reply to: Mairose posted by Dave on January 06, 2021 at 23:37:26:
I think your problem is likely incorrect plumbing. Sounds like a double acting spool on the valve is being used to control a single acting lift cylinder and the unused port on that spool has been plugged. Common mistake. Remove the plug and connect that port to the tank return and your squeal and load will go away.
TOH
